Ir para o conteúdo principal
Dinning Chair Seat Cushion and Upholstery Replacement
O que você precisa
  1. Dinning Chair Seat Cushion and Upholstery Replacement, Dinning Chair Seat Cushion and Upholstery: passo 1, imagem 1 %32 Dinning Chair Seat Cushion and Upholstery Replacement, Dinning Chair Seat Cushion and Upholstery: passo 1, imagem 2 %32
    • Flip the chair upside down to reveal bolts
    • unscrew the bolts off the base of the chair
    • Keep the bolts in a safe place to prevent losing them as you will need them to out the chair back together
  2. Dinning Chair Seat Cushion and Upholstery Replacement: passo 2, imagem 1 %32 Dinning Chair Seat Cushion and Upholstery Replacement: passo 2, imagem 2 %32
    • The staples can be dangerous so proceed with caution while removing them.
    • Remove the staples holding the upholstery fabric in place.
    • Dispose the staples that were removed
  3. Dinning Chair Seat Cushion and Upholstery Replacement: passo 3, imagem 1 %32 Dinning Chair Seat Cushion and Upholstery Replacement: passo 3, imagem 2 %32
    • With a measuring tape and or ruler, measure the outline of the base of the seat
    • With a pen, create the outline of the base of the seat
    • Cut with scissors or with a blade along the outline you drew
  4. Dinning Chair Seat Cushion and Upholstery Replacement: passo 4, imagem 1 %32 Dinning Chair Seat Cushion and Upholstery Replacement: passo 4, imagem 2 %32 Dinning Chair Seat Cushion and Upholstery Replacement: passo 4, imagem 3 %32
    • Staple gun can be dangerous if it’s not safely used
    • Grab your new upholstery fabric and cover the foam down to the bottom of the wooden base
    • staple the fabric to the base and make sure it stays on tight
  5. Dinning Chair Seat Cushion and Upholstery Replacement: passo 5, imagem 1 %32 Dinning Chair Seat Cushion and Upholstery Replacement: passo 5, imagem 2 %32
    • Assemble the chair back together with the bolts previously removed
Conclusão
If you followed along with the steps, you should now be looking at a chair that not only looks awesome but feels great to sit in too. Just remember, the skills you've learned today aren't just for fixing chairs—they can apply to all sorts of furniture projects. So keep your tools handy and your creativity flowing. Thanks for sticking with me through this process. Here's to many more successful DIY adventures!
Uma outra pessoa concluiu este guia.
Davidg25
Membro desde: 03/20/24
121 Reputação
Autoria de 1 guia
Equipe
Um comentário
You skipped a lot of steps that would have been helpful. Like step 3 measure and cut what? It looks like foam for the seat. How do I know whether I need to replace the foam or just add more foam? What type of foam do I use? Should I place a filler on top of the foam? What about the fabric for step 4? What type of fabric do I need? How do I figure out how much fabric to use? What steps do I use to staple the fabric in place so it's tight and will stay put?
Good tutorial if someone just needs a refresher on the steps. But there's no way a first timer is following this and coming out with anything but frustration.
krista.irwin@comcast.net - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 50
Ao todo: 640
