Ir para o conteúdo principal
Digital2 Platinum Pad 9 Battery Replacement
O que você precisa
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: passo 1, imagem 1 %32
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: passo 2, imagem 1 %32 Digital2 Platinum Pad 9 Battery Replacement: passo 2, imagem 2 %32
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: passo 3, imagem 1 %32 Digital2 Platinum Pad 9 Battery Replacement: passo 3, imagem 2 %32
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: passo 4, imagem 1 %32
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: passo 5, imagem 1 %32
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: passo 6, imagem 1 %32 Digital2 Platinum Pad 9 Battery Replacement: passo 6, imagem 2 %32
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: passo 7, imagem 1 %32
Conclusão
David DeMeritt
Membro desde: 03/08/16
637 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 5-6, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
Membros da 3
Autoria de 6 guias
Um comentário
Where can one buy the battery?
BedfordGlen Board - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 299
