Ir para o conteúdo principal
Digital2 D2-912 Speaker Replacement
O que você precisa
  1. Digital2 D2-912 Speaker Replacement, External Cover: passo 1, imagem 1 %32
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Speaker Replacement: passo 2, imagem 1 %32 Digital2 D2-912 Speaker Replacement: passo 2, imagem 2 %32
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Digital2 D2-912 Speaker Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 1-1, Harley Fall 2015 Membro de IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 173
