Ir para o conteúdo principal
Digiland DL1168A Front/Rear Camera Replacement
O que você precisa
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: passo 1, imagem 1 %32
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Front/Rear Camera Replacement: passo 2, imagem 1 %32 Digiland DL1168A Front/Rear Camera Replacement: passo 2, imagem 2 %32
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Front/Rear Camera Replacement: passo 3, imagem 1 %32 Digiland DL1168A Front/Rear Camera Replacement: passo 3, imagem 2 %32
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the cover that keeps the camera lens in place.
  5. Digiland DL1168A Front/Rear Camera Replacement: passo 5, imagem 1 %32
    • Use tweezers to gently begin to lift the back piece off.
    • Lift gently because the lens is connected to the back piece by a small cord.
  6. Digiland DL1168A Front/Rear Camera Replacement: passo 6, imagem 1 %32
    • After lifting gently both the lens and the back piece will be removed.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 221
