Ir para o conteúdo principal
Digiland DL1168A Battery Replacement
O que você precisa
  1. Digiland DL1168A Battery Replacement, Rear Case: passo 1, imagem 1 %32
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Battery Replacement: passo 2, imagem 1 %32 Digiland DL1168A Battery Replacement: passo 2, imagem 2 %32
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Battery Replacement: passo 3, imagem 1 %32 Digiland DL1168A Battery Replacement: passo 3, imagem 2 %32
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Battery Replacement, Battery: passo 4, imagem 1 %32 Digiland DL1168A Battery Replacement, Battery: passo 4, imagem 2 %32 Digiland DL1168A Battery Replacement, Battery: passo 4, imagem 3 %32
    • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
    • The soldering tool is hot, and will burn. Follow this link for instructions on Como soldar e dessoldar contatos.
  5. Digiland DL1168A Battery Replacement: passo 5, imagem 1 %32 Digiland DL1168A Battery Replacement: passo 5, imagem 2 %32
    • Using an opening tool, separate the battery from the tablet.
    • Follow the edge of the battery to loosen the glue.
  6. Digiland DL1168A Battery Replacement: passo 6, imagem 1 %32 Digiland DL1168A Battery Replacement: passo 6, imagem 2 %32 Digiland DL1168A Battery Replacement: passo 6, imagem 3 %32
    • Once the glue is loosened, pry the battery away from the screen.
    • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 451
