Ir para o conteúdo principal
DigiTech RP70 Motherboard Replacement
O que você precisa
    1. DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Pergunte ao FixBot
      Comentar
    2. DigiTech RP70 Motherboard Replacement: passo 2, imagem 1 %32 DigiTech RP70 Motherboard Replacement: passo 2, imagem 2 %32
      • Remove the back panel to expose the motherboard.
      Pergunte ao FixBot
      Comentar
    3. DigiTech RP70 Motherboard Replacement: passo 3, imagem 1 %32
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Pergunte ao FixBot
      Comentar
    4. DigiTech RP70 Motherboard Replacement: passo 4, imagem 1 %32
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
4Comentários do guia
My digitech rp 80 not work. How to get new motherboard
Thadevus - Responder Compartilhar
My digitecj rp 80 not working. No display no sound how to get new motherboard
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Responder Compartilhar
Quiero comprar una estoy en Ecuador. Quiero comprar la moterboard
Lenin Omar Guerra Chango - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 1,354
