Ir para o conteúdo principal
DigiTech RP70 DC Power Connector Replacement
O que você precisa
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: passo 1, imagem 1 %32 DigiTech RP70 DC Power Connector Replacement, Motherboard: passo 1, imagem 2 %32
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: passo 2, imagem 1 %32 DigiTech RP70 DC Power Connector Replacement: passo 2, imagem 2 %32
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: passo 3, imagem 1 %32
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: passo 4, imagem 1 %32
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: passo 5, imagem 1 %32
    • Desolder the back of the motherboard where the power connector is located.
Conclusão
Um comentário
Later? I cant see to other
ISAAC SALAZAR - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 314
