Ir para o conteúdo principal
DigiTech RP70 Footswitch Replacement
O que você precisa
  1. DigiTech RP70  Footswitch Replacement, Motherboard: passo 1, imagem 1 %32 DigiTech RP70  Footswitch Replacement, Motherboard: passo 1, imagem 2 %32
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
    Pergunte ao FixBot
    Comentar
  2. DigiTech RP70  Footswitch Replacement: passo 2, imagem 1 %32 DigiTech RP70  Footswitch Replacement: passo 2, imagem 2 %32
    • Remove the back panel to expose the motherboard.
    Pergunte ao FixBot
    Comentar
  3. DigiTech RP70  Footswitch Replacement: passo 3, imagem 1 %32
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    Pergunte ao FixBot
    Comentar
  4. DigiTech RP70  Footswitch Replacement: passo 4, imagem 1 %32
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    Pergunte ao FixBot
    Comentar
  5. DigiTech RP70  Footswitch Replacement, Footswitches: passo 5, imagem 1 %32 DigiTech RP70  Footswitch Replacement, Footswitches: passo 5, imagem 2 %32 DigiTech RP70  Footswitch Replacement, Footswitches: passo 5, imagem 3 %32
    • Pull firmly on the binder clips that are holding the footswitches in place to remove them.
    • To get the binder clips back in place, you will need to attach handles from another binder clip to hold them open.
    Pergunte ao FixBot
    Comentar
  6. DigiTech RP70  Footswitch Replacement: passo 6, imagem 1 %32
    • Pull the footswitch down and upwards to remove it from the casing.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
So what is the fix? Replacing both foot switches with new ones? Or removing them and reinstalling them will fix the problem of them not working at all? What’s Step 7? If you stop after completing Step 6 you now just have a casing without foot switches. What will fix the problem of them not working qt all after removing the foot switches?
Carl - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 1,407
