Ir para o conteúdo principal
DigiLand DL801W Screen Replacement
O que você precisa
    1. DigiLand DL801W Screen Replacement, Screen: passo 1, imagem 1 %32
      • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
      • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
      • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
      • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
      Pergunte ao FixBot
      Comentar
    2. DigiLand DL801W Screen Replacement: passo 2, imagem 1 %32
      • Once the back panel has been removed, it is best to set it aside in a safe location.
      • By using the J000 screwdriver, remove the 10 screws from the back. When the tablet is oriented like the picture, there are 6 screws to the left and 4 screws to the right. Set aside the screws in a safe place for re-installation.
      Pergunte ao FixBot
      Comentar
    3. DigiLand DL801W Screen Replacement: passo 3, imagem 1 %32 DigiLand DL801W Screen Replacement: passo 3, imagem 2 %32 DigiLand DL801W Screen Replacement: passo 3, imagem 3 %32
      • Disconnect the any wires that are connected to the motherboard.
      • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
      Pergunte ao FixBot
      Comentar
    4. DigiLand DL801W Screen Replacement: passo 4, imagem 1 %32
      • Make sure not to damage the motherboard and components.
      • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
      Pergunte ao FixBot
      Comentar
    5. DigiLand DL801W Screen Replacement: passo 5, imagem 1 %32
      • After removing the motherboard, remove the LCD screen.
      • There are tabs around the LCD screen. Use the spudger to help remove.
      Pergunte ao FixBot
      Comentar
    6. DigiLand DL801W Screen Replacement: passo 6, imagem 1 %32
      • After removing the LCD screen, you should have four main components: The back cover, the motherboard and bracket, the LCD screen, and the front cover.
      • The screen is connected to the front cover. Carefully remove the cracked screen. The screen is connected by an adhesive.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
IUPUI, Team 3-4, Harley Fall 2015 Membro de IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Membros
Autoria de 10 guias
3Comentários do guia
I can't find a replacement lcd screen mine has the rainbow colored liquid marks on the lcd and there's lines going across the screen i have the digiland model# DL801W 8" Windows 10 tablet
eachespeaches - Responder Compartilhar
Yes Amazon supposedly has them for $19. I need one myself as it is cracked. The protection & cover not protect it.
Lilian Reitor - Responder Compartilhar
Where can i find a replacement lcd display screen for digiland DL801W i do not need the digitizer i just need the inner lcd screen
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 3,088
