Ir para o conteúdo principal
DigiLand DL8006 Motherboard Replacement
O que você precisa
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  2. DigiLand DL8006 Motherboard Replacement: passo 2, imagem 1 %32
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
    Pergunte ao FixBot
    Comentar
  3. DigiLand DL8006 Motherboard Replacement: passo 3, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 3, imagem 2 %32 DigiLand DL8006 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
    Pergunte ao FixBot
    Comentar
  4. DigiLand DL8006 Motherboard Replacement: passo 4, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
    Pergunte ao FixBot
    Comentar
  5. DigiLand DL8006 Motherboard Replacement: passo 5, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
    Pergunte ao FixBot
    Comentar
  6. DigiLand DL8006 Motherboard Replacement: passo 6, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 6, imagem 2 %32 DigiLand DL8006 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
    Pergunte ao FixBot
    Comentar
  7. DigiLand DL8006 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently remove the motherboard from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 465
