Ir para o conteúdo principal
DigiLand DL700D Motherboard Replacement
O que você precisa
  1. DigiLand DL700D Motherboard Replacement, Battery: passo 1, imagem 1 %32 DigiLand DL700D Motherboard Replacement, Battery: passo 1, imagem 2 %32 DigiLand DL700D Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Remove the device's back cover using the plastic opening tool.
  2. DigiLand DL700D Motherboard Replacement: passo 2, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 2, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. DigiLand DL700D Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the wifi antenna from the bottom of the battery.
  4. DigiLand DL700D Motherboard Replacement: passo 4, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 4, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 4, imagem 3 %32
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  5. DigiLand DL700D Motherboard Replacement: passo 5, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 5, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
  6. DigiLand DL700D Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Desolder the WiFi antenna from the motherboard.
  7. DigiLand DL700D Motherboard Replacement: passo 7, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 7, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 7, imagem 3 %32
    • Remove 3 ribbon cables attached to the motherboard by lifting the plastic retainer, then pulling the cable out.
  8. DigiLand DL700D Motherboard Replacement: passo 8, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 8, imagem 2 %32
    • Remove adhesive attaching the motherboard to the casing.
  9. DigiLand DL700D Motherboard Replacement: passo 9, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 9, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 9, imagem 3 %32
    • Remove the three 2.5 mm Phillips #1 screws holding the motherboard to the case.
  10. DigiLand DL700D Motherboard Replacement: passo 10, imagem 1 %32 DigiLand DL700D Motherboard Replacement: passo 10, imagem 2 %32 DigiLand DL700D Motherboard Replacement: passo 10, imagem 3 %32
    • Remove motherboard from the case and replace.
Conclusão
To reassemble, follow these instructions in reverse order.
Justin Edwards
Membro desde: 03/29/18
241 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G4, Harley Spring 2018 Membro de IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 277
