Ir para o conteúdo principal
DigiLand DL1010Q Battery Replacement
O que você precisa
  1. DigiLand DL1010Q Battery Replacement, Rear Case: passo 1, imagem 1 %32
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Battery Replacement: passo 2, imagem 1 %32 DigiLand DL1010Q Battery Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Battery Replacement: passo 3, imagem 1 %32
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Battery Replacement, Battery: passo 4, imagem 1 %32 DigiLand DL1010Q Battery Replacement, Battery: passo 4, imagem 2 %32
    • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
    • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
  5. DigiLand DL1010Q Battery Replacement: passo 5, imagem 1 %32 DigiLand DL1010Q Battery Replacement: passo 5, imagem 2 %32
    • Using a metal spudger tool, wedge between battery and metal screen.
    • Follow the edge of the battery to loosen the glue.
  6. DigiLand DL1010Q Battery Replacement: passo 6, imagem 1 %32 DigiLand DL1010Q Battery Replacement: passo 6, imagem 2 %32
    • Once the glue is loosened, you should be able to pry off the battery from the screen.
    • Using your hands, pull up on the battery to pull battery off.
    • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    • The battery will be completely disconnected and you can set the battery aside in a safe place.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 4,445
