Ir para o conteúdo principal
Dewalt DCD778 Motor Replacement
O que você precisa
  1. Dewalt DCD778 Motor Replacement, Battery: passo 1, imagem 1 %32
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Motor Replacement: passo 2, imagem 1 %32
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Motor Replacement: passo 3, imagem 1 %32
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Motor Replacement, Motor: passo 4, imagem 1 %32 Dewalt DCD778 Motor Replacement, Motor: passo 4, imagem 2 %32
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Motor Replacement: passo 5, imagem 1 %32
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Motor Replacement: passo 6, imagem 1 %32
    • Lift the drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
  7. Dewalt DCD778 Motor Replacement: passo 7, imagem 1 %32 Dewalt DCD778 Motor Replacement: passo 7, imagem 2 %32
    • Slightly twist and pull motor away from the clutch.
  8. Dewalt DCD778 Motor Replacement: passo 8, imagem 1 %32
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
Conclusão
Brittany
Membro desde: 03/09/19
693 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 42
Duração total: 1,394
