Ir para o conteúdo principal
Determining Wire Connectivity for Skullcandy Lowrider
O que você precisa
  1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: passo 1, imagem 1 %32 Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: passo 1, imagem 2 %32
    • Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
  2. Determining Wire Connectivity for Skullcandy Lowrider: passo 2, imagem 1 %32 Determining Wire Connectivity for Skullcandy Lowrider: passo 2, imagem 2 %32
    • Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
  3. Determining Wire Connectivity for Skullcandy Lowrider: passo 3, imagem 1 %32
    • Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
    • Here, you will be able to check the connectivity of your auxiliary cord to its port in an appropriate ear-cup.
  4. Determining Wire Connectivity for Skullcandy Lowrider: passo 4, imagem 1 %32
    • Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
    • Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
Conclusão
Ryley
Membro desde: 01/16/15
273 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 983
