Ir para o conteúdo principal
Skullcandy Lowrider Wiring Repair
O que você precisa
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, imagem 1 %32 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, imagem 2 %32 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, imagem 3 %32
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: passo 2, imagem 1 %32 Skullcandy Lowrider Wiring Repair: passo 2, imagem 2 %32
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: passo 3, imagem 1 %32 Skullcandy Lowrider Wiring Repair: passo 3, imagem 2 %32 Skullcandy Lowrider Wiring Repair: passo 3, imagem 3 %32
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: passo 4, imagem 1 %32
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
Conclusão
Ryley
Membro desde: 01/16/15
273 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Duração total: 640
