Ir para o conteúdo principal
Desktop PC Left Panel Replacement
O que você precisa
  1. Desktop PC Left Panel Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    Pergunte ao FixBot
    Comentar
  2. Desktop PC Left Panel Replacement: passo 2, imagem 1 %32 Desktop PC Left Panel Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    Pergunte ao FixBot
    Comentar
Conclusão
24 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.198 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 49 guias
3Comentários do guia
What is the name of the case used in this tutorial?
Nicolas Hunter - Responder Compartilhar
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Responder Compartilhar
I have this same case in black and want to know what model it is.
numanair - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 95
Ao todo: 9,836
