Ir para o conteúdo principal
Desktop PC Graphics Card Replacement
O que você precisa
    1. Desktop PC Graphics Card Replacement, Left Panel: passo 1, imagem 1 %32
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Pergunte ao FixBot
      Comentar
    2. Desktop PC Graphics Card Replacement: passo 2, imagem 1 %32 Desktop PC Graphics Card Replacement: passo 2, imagem 2 %32
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Pergunte ao FixBot
      Comentar
    1. Desktop PC Graphics Card Replacement, Graphics Card: passo 3, imagem 1 %32
      • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
      • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
      Pergunte ao FixBot
      Comentar
    2. Desktop PC Graphics Card Replacement: passo 4, imagem 1 %32 Desktop PC Graphics Card Replacement: passo 4, imagem 2 %32
      • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
      • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
      Pergunte ao FixBot
      Comentar
Conclusão
86 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.198 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 53 guias
3Comentários do guia
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Ons NA - Responder Compartilhar
I have a all in one pc so this is not relevant
Robert Campanelli - Responder Compartilhar
any diffrerences in slots?
benzy aceware - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 35
Últimos 30 dias: 132
Ao todo: 20,799
