Ir para o conteúdo principal
Desktop PC Front Fan Replacement
O que você precisa
    1. Desktop PC Front Fan Replacement, Left Panel: passo 1, imagem 1 %32
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Pergunte ao FixBot
      Comentar
    2. Desktop PC Front Fan Replacement: passo 2, imagem 1 %32 Desktop PC Front Fan Replacement: passo 2, imagem 2 %32
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Pergunte ao FixBot
      Comentar
    1. Desktop PC Front Fan Replacement, Front Fan: passo 3, imagem 1 %32 Desktop PC Front Fan Replacement, Front Fan: passo 3, imagem 2 %32
      • Push to unlatch three grey connectors on the front panel.
      Pergunte ao FixBot
      Comentar
    2. Desktop PC Front Fan Replacement: passo 4, imagem 1 %32
      • Disconnect the front panel from the computer face.
      Pergunte ao FixBot
      Comentar
    3. Desktop PC Front Fan Replacement: passo 5, imagem 1 %32
      • Remove four Phillips #2 head, 5mm screws holding in the fan.
      Pergunte ao FixBot
      Comentar
    4. Desktop PC Front Fan Replacement: passo 6, imagem 1 %32
      • Slide the fan out from the side of the casing.
      Pergunte ao FixBot
      Comentar
    5. Desktop PC Front Fan Replacement: passo 7, imagem 1 %32
      • Disconnect the power cable from the fan.
      Pergunte ao FixBot
      Comentar
Conclusão
39 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.198 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 53 guias
2Comentários do guia
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Responder Compartilhar
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 184
Ao todo: 31,704
