Ir para o conteúdo principal
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
O que você precisa
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: passo 1, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: passo 1, imagem 2 %32
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 2, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 2, imagem 2 %32
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 3, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 3, imagem 2 %32
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 4, imagem 1 %32
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 5, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 5, imagem 2 %32
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 6, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 6, imagem 2 %32
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 7, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 7, imagem 2 %32
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 8, imagem 1 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 8, imagem 2 %32 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: passo 8, imagem 3 %32
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Theodore Tan
Membro desde: 02/24/15
137 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
Membros da 7
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 579
