Ir para o conteúdo principal
Dell XPS M1730 Screen Replacement
O que você precisa
  1. Dell XPS M1730 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Push the sliding button near the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Dell XPS M1730 Screen Replacement: passo 2, imagem 1 %32
    • Slide the button next to the battery and lift up on the lip of the battery edge.
    Pergunte ao FixBot
    Comentar
  3. Dell XPS M1730 Screen Replacement: passo 3, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 3, imagem 2 %32
    • Lift and remove the battery.
    Pergunte ao FixBot
    Comentar
  4. Dell XPS M1730 Screen Replacement, Keyboard: passo 4, imagem 1 %32 Dell XPS M1730 Screen Replacement, Keyboard: passo 4, imagem 2 %32 Dell XPS M1730 Screen Replacement, Keyboard: passo 4, imagem 3 %32
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
    Pergunte ao FixBot
    Comentar
  5. Dell XPS M1730 Screen Replacement: passo 5, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 5, imagem 2 %32
    • Remove the four screws from the top of the keyboard bracket.
    Pergunte ao FixBot
    Comentar
  6. Dell XPS M1730 Screen Replacement: passo 6, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 6, imagem 2 %32 Dell XPS M1730 Screen Replacement: passo 6, imagem 3 %32
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
    Pergunte ao FixBot
    Comentar
  7. Dell XPS M1730 Screen Replacement: passo 7, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 7, imagem 2 %32 Dell XPS M1730 Screen Replacement: passo 7, imagem 3 %32
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
    Pergunte ao FixBot
    Comentar
  8. Dell XPS M1730 Screen Replacement, LCD Screen Display: passo 8, imagem 1 %32
    • Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Dell XPS M1730 Screen Replacement: passo 9, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 9, imagem 2 %32 Dell XPS M1730 Screen Replacement: passo 9, imagem 3 %32
    • Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
    Pergunte ao FixBot
    Comentar
  10. Dell XPS M1730 Screen Replacement: passo 10, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 10, imagem 2 %32 Dell XPS M1730 Screen Replacement: passo 10, imagem 3 %32
    • Disconnect the display connectors by removing them from the grooves and unplugging them.
    Pergunte ao FixBot
    Comentar
  11. Dell XPS M1730 Screen Replacement: passo 11, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 11, imagem 2 %32 Dell XPS M1730 Screen Replacement: passo 11, imagem 3 %32
    • Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Dell XPS M1730 Screen Replacement: passo 12, imagem 1 %32 Dell XPS M1730 Screen Replacement: passo 12, imagem 2 %32
    • Disconnect the display connector behind the top of the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 37
Ao todo: 1,628
