Introdução
This guide helps you to upgrade or replace your wireless card to a new Wi-Fi standard if you have determined that the reason your wireless internet is not working is because of a hardware issue with the card.
O que você precisa
Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
Two 4.7mm Philips #1 screws
Uma outra pessoa concluiu este guia.
