Introdução
If your computer is still running hot after cleaning the fan, you should remove the heat sink to check that it is not damaged.
O que você precisa
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Uma outra pessoa concluiu este guia.
