Ir para o conteúdo principal
Dell XPS 720 H2C Memory Modules Replacement
    1. Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: passo 1, imagem 1 %32 Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: passo 1, imagem 2 %32
      • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, imagem 1 %32 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, imagem 2 %32 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: passo 2, imagem 3 %32
      • The memory modules are located directly above the XPS processor and are attached to the motherboard.
      • There are notches securing the memory modules onto the motherboard.
      • Push down and outward on the both notches to release each memory module from the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 720 H2C Memory Modules Replacement: passo 3, imagem 1 %32
      • Carefully remove each memory module from its slot.
      • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 4-16, Maness Spring 2013 Membro de Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 1,580
