Ir para o conteúdo principal
Dell XPS 18 Touch Control Board Replacement
O que você precisa
    1. Dell XPS 18 Touch Control Board Replacement, Back Cover: passo 1, imagem 1 %32
      • Turn the device on its screen.
      • Remove the ten 4mm screws using a T8 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 18 Touch Control Board Replacement: passo 2, imagem 1 %32
      • Gently flip out support feet located near the bottom of device.
      Pergunte ao FixBot
      Comentar
    3. Dell XPS 18 Touch Control Board Replacement: passo 3, imagem 1 %32
      • Gently lift the back cover off the device. The back cover should come off easily.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 18 Touch Control Board Replacement, Internal Cover: passo 4, imagem 1 %32
      • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 18 Touch Control Board Replacement: passo 5, imagem 1 %32 Dell XPS 18 Touch Control Board Replacement: passo 5, imagem 2 %32
      • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
      Pergunte ao FixBot
      Comentar
    3. Dell XPS 18 Touch Control Board Replacement: passo 6, imagem 1 %32 Dell XPS 18 Touch Control Board Replacement: passo 6, imagem 2 %32
      • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
      • Remove the internal cover.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: passo 7, imagem 1 %32 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: passo 7, imagem 2 %32
      • Disconnect the black camera cable and pull it back to prevent future hassle.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 18 Touch Control Board Replacement: passo 8, imagem 1 %32 Dell XPS 18 Touch Control Board Replacement: passo 8, imagem 2 %32
      • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
      • Disconnect the silver and blue touch control board cable.
      Pergunte ao FixBot
      Comentar
    3. Dell XPS 18 Touch Control Board Replacement: passo 9, imagem 1 %32 Dell XPS 18 Touch Control Board Replacement: passo 9, imagem 2 %32
      • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
      • Remove the touch control board.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Austin Weir
Membro desde: 01/31/15
1.308 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-29, Amido Winter 2015 Membro de Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Membros
Autoria de 16 guias
2Comentários do guia
It worked perfectly. Thank you.
Kenneth Macdonald - Responder Compartilhar
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 2,318
