Ir para o conteúdo principal
Dell XPS 15 9570 Heat Sink Replacement
O que você precisa
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: passo 1, imagem 1 %32
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: passo 2, imagem 1 %32 Dell XPS 15 9570 Heat Sink Replacement: passo 2, imagem 2 %32 Dell XPS 15 9570 Heat Sink Replacement: passo 2, imagem 3 %32
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: passo 3, imagem 1 %32 Dell XPS 15 9570 Heat Sink Replacement: passo 3, imagem 2 %32
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: passo 5, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: passo 6, imagem 1 %32
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: passo 7, imagem 1 %32
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: passo 8, imagem 1 %32 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: passo 8, imagem 2 %32
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: passo 9, imagem 1 %32
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 51
Ao todo: 2,792
