Ir para o conteúdo principal
Dell XPS 15 9550 RAM Replacement
O que você precisa
    1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: passo 1, imagem 1 %32
      • Turn the laptop upside down.
      • Make sure the laptop is turned off.
      • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 15 9550 RAM Replacement: passo 2, imagem 1 %32 Dell XPS 15 9550 RAM Replacement: passo 2, imagem 2 %32
      • Open up the information panel door (on the middle of the back side).
      • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
      Pergunte ao FixBot
      Comentar
    3. Dell XPS 15 9550 RAM Replacement: passo 3, imagem 1 %32 Dell XPS 15 9550 RAM Replacement: passo 3, imagem 2 %32 Dell XPS 15 9550 RAM Replacement: passo 3, imagem 3 %32
      • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
      • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
      Pergunte ao FixBot
      Comentar
    1. Dell XPS 15 9550 RAM Replacement, RAM: passo 4, imagem 1 %32 Dell XPS 15 9550 RAM Replacement, RAM: passo 4, imagem 2 %32
      • There are 2 separate RAM sticks.
      • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
      • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
      Pergunte ao FixBot
      Comentar
    2. Dell XPS 15 9550 RAM Replacement: passo 5, imagem 1 %32 Dell XPS 15 9550 RAM Replacement: passo 5, imagem 2 %32
      • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
jbaseballin2
Membro desde: 10/04/18
123 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team S6-G1, Ogden Fall 2018 Membro de UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Membros
Autoria de 23 guias
1Comentário do guia
What type ram do you replace it with? Could you post a link?
twrfan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 37
Ao todo: 9,712
