Ir para o conteúdo principal
Dell XPS 15 9510 Fan Replacement
O que você precisa
  1. Dell XPS 15 9510 Fan Replacement, Rear Panel: passo 1, imagem 1 %32
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: passo 2, imagem 1 %32
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: passo 3, imagem 1 %32
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: passo 4, imagem 1 %32 Dell XPS 15 9510 Fan Replacement, Fan: passo 4, imagem 2 %32
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: passo 5, imagem 1 %32 Dell XPS 15 9510 Fan Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: passo 6, imagem 1 %32
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: passo 7, imagem 1 %32 Dell XPS 15 9510 Fan Replacement: passo 7, imagem 2 %32
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: passo 8, imagem 1 %32 Dell XPS 15 9510 Fan Replacement: passo 8, imagem 2 %32 Dell XPS 15 9510 Fan Replacement: passo 8, imagem 3 %32
    • Repeat the previous step and remove the other fan.
Conclusão
Bethany Wright
Membro desde: 07/13/23
403 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-1, Harley Summer 2023 Membro de IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 57
Duração total: 697
