Ir para o conteúdo principal
Dell XPS 14 Wi-Fi Card Replacement
O que você precisa
  1. Dell XPS 14 Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Wi-Fi Card Replacement: passo 3, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 4, imagem 2 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Wi-Fi Card Replacement, Speaker: passo 5, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement, Speaker: passo 5, imagem 2 %32
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 6, imagem 2 %32
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 Wi-Fi Card Replacement, Battery: passo 7, imagem 1 %32
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 Wi-Fi Card Replacement: passo 8, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 8, imagem 2 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 8, imagem 3 %32
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 Wi-Fi Card Replacement, Wi-Fi Card: passo 9, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement, Wi-Fi Card: passo 9, imagem 2 %32
    • Remove the Wi-Fi card by gently lifting the card and pulling it out of its slot.
  10. Dell XPS 14 Wi-Fi Card Replacement: passo 10, imagem 1 %32 Dell XPS 14 Wi-Fi Card Replacement: passo 10, imagem 2 %32
    • Disconnect the two coaxial cables from the Wi-Fi card to remove it from the laptop.
Conclusão
Gabriella Monico
Membro desde: 03/23/22
457 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-3, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-3, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 191
