Ir para o conteúdo principal
Dell XPS 13 9310 Lower Case Replacement
O que você precisa
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: passo 1, imagem 1 %32 Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: passo 1, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: passo 2, imagem 1 %32 Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: passo 3, imagem 1 %32 Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: passo 3, imagem 2 %32
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, imagem 1 %32 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, imagem 2 %32 Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: passo 4, imagem 3 %32
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Lower Case Replacement: passo 5, imagem 1 %32 Dell XPS 13 9310 Lower Case Replacement: passo 5, imagem 2 %32 Dell XPS 13 9310 Lower Case Replacement: passo 5, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusão
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Spencer Day
Membro desde: 09/14/22
59.657 Reputação
Autoria de 430 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 41
Últimos 30 dias: 123
Duração total: 1,500
