Introdução
Follow this guide to replace the back cover on your Dell XPS 13 9305. This is necessary to perform nearly every repair for this device. Luckily, the back cover removes fairly easily.
O que você precisa
Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
At each corner, insert an opening pick between the back cover and the device body.
Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
Lift the front edge of the cover away from you.
Remove the back cover from the laptop.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
