Ir para o conteúdo principal
Dell Vostro V130 Memory Module Replacement
O que você precisa
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: passo 1, imagem 1 %32
    • Remove the screws that secure the base cover to the computer.
    Pergunte ao FixBot
    Comentar
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: passo 2, imagem 1 %32
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
    Pergunte ao FixBot
    Comentar
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: passo 3, imagem 1 %32
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    Pergunte ao FixBot
    Comentar
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the battery to the computer.
    Pergunte ao FixBot
    Comentar
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: passo 5, imagem 1 %32
    • Lift the battery up and away from the computer.
    Pergunte ao FixBot
    Comentar
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: passo 6, imagem 1 %32
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
    Pergunte ao FixBot
    Comentar
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: passo 7, imagem 1 %32
    • Pull the LED cover toward the keyboard and remove it from the computer.
    Pergunte ao FixBot
    Comentar
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: passo 8, imagem 1 %32
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Pergunte ao FixBot
    Comentar
  9. Dell Vostro V130 Memory Module Replacement: passo 9, imagem 1 %32
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 613
