Ir para o conteúdo principal
Dell Vostro 5459 Memory Module Replacement
O que você precisa
  1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: passo 1, imagem 1 %32
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
    Pergunte ao FixBot
    Comentar
  2. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: passo 2, imagem 1 %32
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
    Pergunte ao FixBot
    Comentar
  3. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: passo 3, imagem 1 %32
    • Lift the plastic enclosure covering the top of the memory module compartment.
    • Pull the retention clips from the memory module until it pops up.
    • Remove the memory module from the connector on the system board.
    Pergunte ao FixBot
    Comentar
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 500
