Ir para o conteúdo principal
Dell Vostro 3500 Memory Module Replacement
O que você precisa
  1. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Latch: passo 1, imagem 1 %32
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
    Pergunte ao FixBot
    Comentar
  2. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Release Latch: passo 2, imagem 1 %32
    • Slide the other battery release latch to the unlock position.
    Pergunte ao FixBot
    Comentar
  3. Dell Vostro 3500 Memory Module Replacement, Removing the Battery: passo 3, imagem 1 %32
    • Slide the battery and remove it from the computer.
    Pergunte ao FixBot
    Comentar
  4. Dell Vostro 3500 Memory Module Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Turn the laptop over and remove two screws securing the service cover.
    Pergunte ao FixBot
    Comentar
  5. Dell Vostro 3500 Memory Module Replacement, Removing the Base Cover: passo 5, imagem 1 %32
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
    Pergunte ao FixBot
    Comentar
  6. Dell Vostro 3500 Memory Module Replacement, Releasing the Memory Module: passo 6, imagem 1 %32
    • Push apart the memory retention clips to release the memory module.
    Pergunte ao FixBot
    Comentar
  7. Dell Vostro 3500 Memory Module Replacement, Remove the Memory Module: passo 7, imagem 1 %32
    • Remove the memory module from its connector on the system board.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 958
