Introdução
The keyboard helps user input characters and functions when using the laptop. If your key does not function well, you might need to replace the keyboard. This guide will walk you through on how to replace the keyboard.
O que você precisa
Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
