Ir para o conteúdo principal
Dell Vostro 1700 Memory Module Replacement
O que você precisa
  1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: passo 1, imagem 1 %32
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
    Pergunte ao FixBot
    Comentar
  2. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: passo 2, imagem 1 %32
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
    Pergunte ao FixBot
    Comentar
  3. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: passo 3, imagem 1 %32
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
    Pergunte ao FixBot
    Comentar
  4. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: passo 4, imagem 1 %32
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 40
Ao todo: 473
