Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
O que você precisa
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
8 outras pessoas executaram este guia.
2 comentários
unable to open the lock, can the mother board be changed
Great article.
