Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a spudger or your fingers to pry off the back case.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to disconnect the camera from the motherboard.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
8 outras pessoas executaram este guia.
2 comentários
unable to open the lock, can the mother board be changed
Great article.
