Ir para o conteúdo principal
Dell Venue 7 Battery Replacement
O que você precisa
    1. Dell Venue 7 Battery Replacement, Rear Case: passo 1, imagem 1 %32 Dell Venue 7 Battery Replacement, Rear Case: passo 1, imagem 2 %32
      • Use a spudger or your fingers to pry off the back case.
      • If your case is badly damaged, use caution because the fragments may be sharp.
      Pergunte ao FixBot
      Comentar
    1. Dell Venue 7 Battery Replacement, Battery: passo 2, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
      Pergunte ao FixBot
      Comentar
    2. Dell Venue 7 Battery Replacement: passo 3, imagem 1 %32
      • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
      • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
      • Do not bend or warp the battery in any way as it can be a fire hazard.
      Pergunte ao FixBot
      Comentar
Conclusão
chaveza
Membro desde: 01/20/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 11-4, Blackwell Winter 2015 Membro de USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Membros
Autoria de 10 guias
4Comentários do guia
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Responder Compartilhar
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 40
Ao todo: 7,945
