Ir para o conteúdo principal
Dell VRP100 Screen Replacement
O que você precisa
  1. Dell VRP100 Screen Replacement, Cover Panel: passo 1, imagem 1 %32 Dell VRP100 Screen Replacement, Cover Panel: passo 1, imagem 2 %32 Dell VRP100 Screen Replacement, Cover Panel: passo 1, imagem 3 %32
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    Pergunte ao FixBot
    Comentar
  2. Dell VRP100 Screen Replacement: passo 2, imagem 1 %32
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    Pergunte ao FixBot
    Comentar
  3. Dell VRP100 Screen Replacement: passo 3, imagem 1 %32 Dell VRP100 Screen Replacement: passo 3, imagem 2 %32 Dell VRP100 Screen Replacement: passo 3, imagem 3 %32
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    Pergunte ao FixBot
    Comentar
  4. Dell VRP100 Screen Replacement: passo 4, imagem 1 %32 Dell VRP100 Screen Replacement: passo 4, imagem 2 %32 Dell VRP100 Screen Replacement: passo 4, imagem 3 %32
    • Carefully remove the lens and motherboard assembly from the white casing.
    Pergunte ao FixBot
    Comentar
  5. Dell VRP100 Screen Replacement, Screen: passo 5, imagem 1 %32 Dell VRP100 Screen Replacement, Screen: passo 5, imagem 2 %32 Dell VRP100 Screen Replacement, Screen: passo 5, imagem 3 %32
    • Remove the four 2.5 mm PH000 screws by rotating counter-clockwise.
    • Separate the lenses from the motherboard panel.
    Pergunte ao FixBot
    Comentar
  6. Dell VRP100 Screen Replacement: passo 6, imagem 1 %32 Dell VRP100 Screen Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Take off the tape using the blunt nosed tweezers to disconnect the flat-topped connector from the motherboard.
    • The screen is attached to the motherboard using an adhesive.
    Pergunte ao FixBot
    Comentar
  7. Dell VRP100 Screen Replacement: passo 7, imagem 1 %32 Dell VRP100 Screen Replacement: passo 7, imagem 2 %32 Dell VRP100 Screen Replacement: passo 7, imagem 3 %32
    • Lift the yellow tape with tweezers.
    • Remove the ribbon cable from the screen to the motherboard with tweezers.
    Pergunte ao FixBot
    Comentar
  8. Dell VRP100 Screen Replacement: passo 8, imagem 1 %32 Dell VRP100 Screen Replacement: passo 8, imagem 2 %32 Dell VRP100 Screen Replacement: passo 8, imagem 3 %32
    • Remove the six 3.4mm PH000 screws by rotating counter-clockwise connecting the back panel to the screen.
    • Remove the back panel from the screen by carefully pulling apart the two.
    Pergunte ao FixBot
    Comentar
  9. Dell VRP100 Screen Replacement: passo 9, imagem 1 %32 Dell VRP100 Screen Replacement: passo 9, imagem 2 %32 Dell VRP100 Screen Replacement: passo 9, imagem 3 %32
    • Peel away the screen with both hands.
    • A plastic opening tool may be required for removing the screen.
    • Adhesive may need to be reapplied during the rebuild.
    Pergunte ao FixBot
    Comentar
Conclusão
Lauren Monzon
Membro desde: 10/08/18
235 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G1, White Fall 2018 Membro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 34
Ao todo: 1,315
