Ir para o conteúdo principal
Dell VRC100-R Daughterboard Replacement
O que você precisa
  1. Dell VRC100-R Daughterboard Replacement, Battery: passo 1, imagem 1 %32 Dell VRC100-R Daughterboard Replacement, Battery: passo 1, imagem 2 %32 Dell VRC100-R Daughterboard Replacement, Battery: passo 1, imagem 3 %32
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
    Pergunte ao FixBot
    Comentar
  2. Dell VRC100-R Daughterboard Replacement: passo 2, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 2, imagem 2 %32
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    Pergunte ao FixBot
    Comentar
  3. Dell VRC100-R Daughterboard Replacement, Joystick: passo 3, imagem 1 %32 Dell VRC100-R Daughterboard Replacement, Joystick: passo 3, imagem 2 %32 Dell VRC100-R Daughterboard Replacement, Joystick: passo 3, imagem 3 %32
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
    Pergunte ao FixBot
    Comentar
  4. Dell VRC100-R Daughterboard Replacement: passo 4, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 4, imagem 2 %32
    • Grab the joystick and pull away from the controller to remove it.
    Pergunte ao FixBot
    Comentar
  5. Dell VRC100-R Daughterboard Replacement, Daughterboard: passo 5, imagem 1 %32 Dell VRC100-R Daughterboard Replacement, Daughterboard: passo 5, imagem 2 %32
    • Remove one 6mm Phillips #0 screw.
    Pergunte ao FixBot
    Comentar
  6. Dell VRC100-R Daughterboard Replacement: passo 6, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 6, imagem 2 %32
    • Turn your controller over and orient it so that the thin side is on the top.
    • Remove four 4mm Phillips #0 screws.
    Pergunte ao FixBot
    Comentar
  7. Dell VRC100-R Daughterboard Replacement: passo 7, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 7, imagem 2 %32
    • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
    • Push down on the end of the plastic opening tool closest to you to lift the panel up.
    • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
    Pergunte ao FixBot
    Comentar
  8. Dell VRC100-R Daughterboard Replacement: passo 8, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 8, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  9. Dell VRC100-R Daughterboard Replacement: passo 9, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 9, imagem 2 %32 Dell VRC100-R Daughterboard Replacement: passo 9, imagem 3 %32
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the blue cable and pull away from the socket.
    • To reinstall, insert the blue cable into the connector and close the flap on the black line.
    Pergunte ao FixBot
    Comentar
  10. Dell VRC100-R Daughterboard Replacement: passo 10, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 10, imagem 2 %32 Dell VRC100-R Daughterboard Replacement: passo 10, imagem 3 %32
    • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
    • Grab the orange cable and pull away from the socket.
    • To reinstall, insert the orange cable into the connector and close the flap on the white line.
    Pergunte ao FixBot
    Comentar
  11. Dell VRC100-R Daughterboard Replacement: passo 11, imagem 1 %32 Dell VRC100-R Daughterboard Replacement: passo 11, imagem 2 %32
    • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
    Pergunte ao FixBot
    Comentar
Conclusão
22 outras pessoas executaram este guia.
Steven Pineda
Membro desde: 04/16/18
1.049 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G3, Livingston Spring 2018 Membro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Membros
Autoria de 5 guias
1Comentário do guia
Really instructive & easy to follow!
Daisy Chavez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 7,207
