Ir para o conteúdo principal
Dell VRC100-R Battery Replacement
  1. Dell VRC100-R Battery Replacement, Battery: passo 1, imagem 1 %32 Dell VRC100-R Battery Replacement, Battery: passo 1, imagem 2 %32 Dell VRC100-R Battery Replacement, Battery: passo 1, imagem 3 %32
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
    Pergunte ao FixBot
    Comentar
  2. Dell VRC100-R Battery Replacement: passo 2, imagem 1 %32 Dell VRC100-R Battery Replacement: passo 2, imagem 2 %32
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    Pergunte ao FixBot
    Comentar
Conclusão
Kenneth Liu
Membro desde: 04/18/18
169 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G3, Livingston Spring 2018 Membro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Membros
Autoria de 5 guias
1Comentário do guia
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 34
Últimos 30 dias: 64
Ao todo: 1,169
