Ir para o conteúdo principal
Dell Studio 1737 Keyboard Replacement
O que você precisa
  1. Dell Studio 1737 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Studio 1737 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
    Pergunte ao FixBot
    Comentar
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
    Pergunte ao FixBot
    Comentar
  3. Dell Studio 1737 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the 4mm ph1 screw under the battery
    Pergunte ao FixBot
    Comentar
  4. Dell Studio 1737 Keyboard Replacement: passo 4, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 4, imagem 2 %32 Dell Studio 1737 Keyboard Replacement: passo 4, imagem 3 %32
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
    Pergunte ao FixBot
    Comentar
  5. Dell Studio 1737 Keyboard Replacement: passo 5, imagem 1 %32
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
    Pergunte ao FixBot
    Comentar
  6. Dell Studio 1737 Keyboard Replacement: passo 6, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
    Pergunte ao FixBot
    Comentar
  7. Dell Studio 1737 Keyboard Replacement: passo 7, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the ribbon cable as shown
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 945
