Ir para o conteúdo principal
Dell Studio 1555 Keyboard Replacement
O que você precisa
  1. Dell Studio 1555 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
    Pergunte ao FixBot
    Comentar
  2. Dell Studio 1555 Keyboard Replacement: passo 2, imagem 1 %32 Dell Studio 1555 Keyboard Replacement: passo 2, imagem 2 %32 Dell Studio 1555 Keyboard Replacement: passo 2, imagem 3 %32
    • Slide the locking switch to the left to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Studio 1555 Keyboard Replacement: passo 3, imagem 1 %32
    • Gently pull the battery away from the device.
    Pergunte ao FixBot
    Comentar
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
    Pergunte ao FixBot
    Comentar
  5. Dell Studio 1555 Keyboard Replacement: passo 5, imagem 1 %32 Dell Studio 1555 Keyboard Replacement: passo 5, imagem 2 %32
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
    Pergunte ao FixBot
    Comentar
  6. Dell Studio 1555 Keyboard Replacement: passo 6, imagem 1 %32 Dell Studio 1555 Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
    Pergunte ao FixBot
    Comentar
  7. Dell Studio 1555 Keyboard Replacement: passo 7, imagem 1 %32
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Dell Studio 1555 Keyboard Replacement: passo 8, imagem 1 %32 Dell Studio 1555 Keyboard Replacement: passo 8, imagem 2 %32 Dell Studio 1555 Keyboard Replacement: passo 8, imagem 3 %32
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
    Pergunte ao FixBot
    Comentar
  9. Dell Studio 1555 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the keyboard
    Pergunte ao FixBot
    Comentar
Conclusão
Hunter Tuck
Membro desde: 10/10/16
214 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 1,264
