Ir para o conteúdo principal
Dell Studio 1555 Display Replacement
O que você precisa
  1. Dell Studio 1555 Display Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
    Pergunte ao FixBot
    Comentar
  2. Dell Studio 1555 Display Replacement: passo 2, imagem 1 %32 Dell Studio 1555 Display Replacement: passo 2, imagem 2 %32 Dell Studio 1555 Display Replacement: passo 2, imagem 3 %32
    • Slide the locking switch to the left to release the battery.
    Pergunte ao FixBot
    Comentar
  3. Dell Studio 1555 Display Replacement: passo 3, imagem 1 %32
    • Gently pull the battery away from the device.
    Pergunte ao FixBot
    Comentar
  4. Dell Studio 1555 Display Replacement, Display: passo 4, imagem 1 %32 Dell Studio 1555 Display Replacement, Display: passo 4, imagem 2 %32
    • Insert a plastic opening tool between the bezel and the display cover.
    • Wiggle it to the release the latches.
    • Separate the bezel from the cover.
    Pergunte ao FixBot
    Comentar
  5. Dell Studio 1555 Display Replacement: passo 5, imagem 1 %32 Dell Studio 1555 Display Replacement: passo 5, imagem 2 %32
    • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Dell Studio 1555 Display Replacement: passo 6, imagem 1 %32
    • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
    • Unplug the camera cable.
    Pergunte ao FixBot
    Comentar
  7. Dell Studio 1555 Display Replacement: passo 7, imagem 1 %32 Dell Studio 1555 Display Replacement: passo 7, imagem 2 %32
    • Place the LCD face down on the top cover.
    • Remove the sticky tape securing the video cable connector.
    • Unplug the video cable from the screen.
    Pergunte ao FixBot
    Comentar
  8. Dell Studio 1555 Display Replacement: passo 8, imagem 1 %32 Dell Studio 1555 Display Replacement: passo 8, imagem 2 %32 Dell Studio 1555 Display Replacement: passo 8, imagem 3 %32
    • Remove the LCD from the laptop.
    • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
    • You will have to transfer the mounting brackets to the new screen.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Josh Boone
Membro desde: 10/10/16
586 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 1,915
