O que você precisa
Slide the battery release latch until it clicks into place.
Turn the computer top side up, open the display, and press the power button to ground the system board.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
