Introdução
Use this guide to replace the screen on your Dell Streak 7. This guide will show you how to remove the old display.
O que você precisa
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
