Ir para o conteúdo principal
Dell Streak 7 Screen Replacement
O que você precisa
  1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Screen  Replacement: passo 2, imagem 1 %32
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Screen  Replacement: passo 3, imagem 1 %32
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Screen  Replacement: passo 4, imagem 1 %32
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Screen  Replacement: passo 5, imagem 1 %32 Dell Streak 7 Screen  Replacement: passo 5, imagem 2 %32
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Screen  Replacement: passo 6, imagem 1 %32
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Screen  Replacement: passo 7, imagem 1 %32 Dell Streak 7 Screen  Replacement: passo 7, imagem 2 %32
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Screen  Replacement, Screen: passo 8, imagem 1 %32
    • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
  9. Dell Streak 7 Screen  Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, peel off the tape securing the screen to the metal cage around it.
  10. Dell Streak 7 Screen  Replacement: passo 10, imagem 1 %32 Dell Streak 7 Screen  Replacement: passo 10, imagem 2 %32
    • Pull out the ribbon cables through the opening in the metal cage.
    • Lift up the metal cage surrounding the screen by swinging the cage from one side.
  11. Dell Streak 7 Screen  Replacement: passo 11, imagem 1 %32
    • Remove the screen by lifting the screen from the front glass.
Conclusão
Ali Benjelloun
Membro desde: 10/02/16
376 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 4-6, Passmore Fall 2016 Membro de USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 466
