Ir para o conteúdo principal
Dell Precision M6400 Memory Module Replacement
O que você precisa
  1. Dell Precision M6400 Memory Module Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch and remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: passo 2, imagem 1 %32
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
    Pergunte ao FixBot
    Comentar
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: passo 3, imagem 1 %32
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
    Pergunte ao FixBot
    Comentar
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: passo 4, imagem 1 %32
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
    Pergunte ao FixBot
    Comentar
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: passo 5, imagem 1 %32
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
46.149 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 43
Ao todo: 1,712
