Introdução
Use this guide to replace a faulty optical drive in your Dell Precision M4700.
The optical drive is a piece of hardware that uses laser technology to allow your computer to read, edit, and/or delete information from discs such as DVDs and CDs. A failing optical drive will remove the ability from your computer to read the discs.
Before using this guide, be sure to review the Dell Precision M4700 Troubleshooting Often times, checking for debris in the drive will fix the issue.
O que você precisa
Slide the release latch to unlock the battery.
Flip and remove the battery from the computer.
Uma outra pessoa concluiu este guia.
