Ir para o conteúdo principal
Dell Precision M4600 Memory Module Replacement
O que você precisa
  1. Dell Precision M4600 Memory Module Replacement, Battery: passo 1, imagem 1 %32 Dell Precision M4600 Memory Module Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
    Pergunte ao FixBot
    Comentar
  2. Dell Precision M4600 Memory Module Replacement, Base Cover: passo 2, imagem 1 %32 Dell Precision M4600 Memory Module Replacement, Base Cover: passo 2, imagem 2 %32 Dell Precision M4600 Memory Module Replacement, Base Cover: passo 2, imagem 3 %32
    • Remove the screws that secure the base cover to the computer.
    • Press the rubber feet towards the rear of the system to disengage the bottom door.
    • Remove the base cover from the computer.
    Pergunte ao FixBot
    Comentar
  3. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: passo 3, imagem 1 %32 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: passo 3, imagem 2 %32 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: passo 3, imagem 3 %32
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
    Pergunte ao FixBot
    Comentar
  4. Dell Precision M4600 Memory Module Replacement, KeyBoard: passo 4, imagem 1 %32 Dell Precision M4600 Memory Module Replacement, KeyBoard: passo 4, imagem 2 %32 Dell Precision M4600 Memory Module Replacement, KeyBoard: passo 4, imagem 3 %32
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
    Pergunte ao FixBot
    Comentar
  5. Dell Precision M4600 Memory Module Replacement: passo 5, imagem 1 %32 Dell Precision M4600 Memory Module Replacement: passo 5, imagem 2 %32 Dell Precision M4600 Memory Module Replacement: passo 5, imagem 3 %32
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
    Pergunte ao FixBot
    Comentar
  6. Dell Precision M4600 Memory Module Replacement: passo 6, imagem 1 %32
    • Peel the keyboard data cable away from the keyboard and remove.
    Pergunte ao FixBot
    Comentar
  7. Dell Precision M4600 Memory Module Replacement, Memory Module: passo 7, imagem 1 %32 Dell Precision M4600 Memory Module Replacement, Memory Module: passo 7, imagem 2 %32
    • Flip the the Bottom
    • Gently pry the retention clips away from the memory modules.
    • Remove the memory modules from the computer.
    Pergunte ao FixBot
    Comentar
  8. Dell Precision M4600 Memory Module Replacement: passo 8, imagem 1 %32 Dell Precision M4600 Memory Module Replacement: passo 8, imagem 2 %32
    • Flip to the Top.
    • Gently pry the retention clips away from the memory module.
    • Remove the memory module from the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
46.158 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 1,678
